Natural convection in a closed domain help!
Old   March 21, 2011, 21:23
Default Natural convection in a closed domain help!
Gregory
Yr0gErG is on a distinguished road
Hi guys, I am currently trying to simulate natural convection in a closed car cabin being subjected to irradiation.
However, due to the lack of time I have no time to explore the use of the radiation models.
What thermal wall boundary conditions would be best suited for the task?
I am assuming that the heat comes in only from the front and rear windscreens and the rest of the walls are adiabatic.
Please help if you are able to, thanks!
Yr0gErG is offline   Reply With Quote
Old   March 23, 2011, 03:37
Default help?
Gregory
Hi if it helps more, I am trying to get a temperature distribution that makes physical sense in a car cabin model. Model is meshed using tri and quad cell types. Data shows that the front and rear windscreens reach a temperature close to 330-340K on a very hot day, irradiation = 550 W/m^2.
I am currently relying solely on the flow and energy equations to get my results out.
The big problem is that I am unsure where to plug my values into the boundary conditions for the front and rear windscreens, which i have defined as walls.
If i put 550W/m^2 into the heat flux under the Thermal tab, temperature of the cabin space reaches well over 5000K.
And with the other tabs such as temperature and convection i get strange images (like a green space with red spots)
Please advise!
Old   March 23, 2011, 04:32
jsm
JSM
jsm is on a distinguished road
If you know heat flux value in the windscreen then you can directly apply in wall boundary. But solve in the transient solver.
If temperature rise is around 340k, I think you need not to enable the radiation. But I am not sure how much radiation heat will go in to the cabin.
With regards,
JSM
jsm is offline   Reply With Quote
Old   March 23, 2011, 05:27
Gregory
Originally Posted by jsm View Post
By wall boundary do you mean the Heat generation rate + wall thickness parts?
Also, what do you mean by transient solver? Density solver or unsteady state solver? Is the a certain procedure for that? Thanks for replying by the way!
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 04:22
how to estimage air speed with natural convection? Pei-Ying Hsieh Main CFD Forum 2 May 1, 2008 15:29
Natural Convection in closed hydrothermal system Scott FLUENT 0 March 24, 2008 19:46
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
natural convection at high Rayleigh mauricio FLUENT 2 February 23, 2005 19:43
