Coupled heat and moisture transfer in porous
Old   April 30, 2004, 07:32
Default Coupled heat and moisture transfer in porous
Mike
Hi, All,
I would like to know how to simulate the coupled heat and moisture transfer process in porous materials by FLUENT. Which model shall I choose?
The moisture transfer inside porous materials is a multi-phase and multi-cpmponent process. I intend to setup a microscopic model of this phenomenon, but don't know how to do.
Thanks!!!
Old   May 4, 2004, 12:05
Default Re: Coupled heat and moisture transfer in porous
Mike
Is it possible to use FLUENT to simulate that problem?
Flow through porous medium Kiran AS FLUENT 6 September 16, 2011 07:38
moisture transfer through membrane m. Nasif FLUENT 0 October 23, 2003 03:41
How to simulate heat and mass transfer for drying olivia FLUENT 1 June 20, 2001 13:04
