Interpreted Error in SourceTerm of k-omeca Model
Old   May 10, 2004, 04:05
Default Interpreted Error in SourceTerm of k-omeca Model
Bowling
My FLUENT5.5 has standard k-epsilon model but I would like to build k-omeca model which differ from k-epsilon in source term only. It has strain rate which already have function in FLUENT [Strainrate_Mag(c,t)]. When I interpreted it the message is:
cpp -ID:\FLUENT.INC\fluent5.5/src -ID:\FLUENT.INC\fluent5.5/cortex/src -ID:\FLUENT.INC\fluent5.5/client/src -ID:\FLUENT.INC\fluent5.5/multiport/src -I. -DUDFCONFIG_H="<udfconfig.h>" Test_2.c
Error: Test_2.c: line 63: function "Strainrate_Mag" not found (pc=24).
Error: Test_2.c: line 63: function "Strainrate_Mag" not found (pc=31).
Error: Test_2.c: line 63: function "Strainrate_Mag" not found (pc=238).
Error: Test_2.c: line 63: function "Strainrate_Mag" not found (pc=245).
.entry
Because it said that "call Strainrate_Mag (-1)"
The message on FLUENT is:
Material water-liquid: New property "UDS Diffusivity" has been added. Selecting uds method for "UDS Diffusivity" -- data required.
Material air: New property "UDS Diffusivity" has been added. Selecting uds method for "UDS Diffusivity" -- data required. chip-exec: k_source: wrong return type: void udf function expectedTest_2.c:2: math.h: No such file or directory
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: () chip-exec: k_source: wrong return type: void udf function expected
This is my C code:
#include "udf.h" #include "math.h"
/* Turbulence model constants */
#define C_MU 0.09 #define SIG_TKE 2.0 #define SIG_TDR 2.0 #define C1_D 0.556 #define C2_D 1.92
/*Use-defined scalars*/ enum { TKE, TDR, N_REQUIRED_UDS };
DEFINE_SOURCE(k_source,c,t,dS,eqn) { real G_k;
G_k=C_MU_T(c,t)*SQR(Strainrate_Mag(c,t)); dS[eqn]=-2*C_R(c,t)*C_R(c,t)*C_MU*C_UDSI(c,t,TKE)/C_MU_T(c,t);
return G_k-(C_R(c,t)*C_R(c,t)*C_MU*SQR(C_UDSI(c,t,TKE))/C_MU_T(c,t)); }
DEFINE_SOURCE(d_source,c,t,dS,eqn) { real G_k;
dS[eqn]=-2*C_R(c,t)*C_R(c,t)*C_MU*C_UDSI(c,t,TKE);
return C1_D*C_UDSI(c,t,TDR)*G_k/C_UDSI(c,t,TKE)-C2_D*C_R(c,t)*SQR(C_UDSI(c,t,TDR))/C_UDSI(c,t,TKE); }
DEFINE_ADJUST(turb_adjust , domain) {
Thread *t;
cell_t c;
/* set the turbulent viscosity */
thread_loop_c(t,domain)
if (FLUID_THREAD_P(t))
begin_c_loop(c,t)
C_MU_T(c,t) =C_R(c,t)*C_UDSI(c,t,TKE)/C_UDSI(c,t,TDR);
end_c_loop(c,t)
Another problem, at if (FLUID_THREAD_P(t)) it said structure reference not implemented. I don't know why.
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 15:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
model han Main CFD Forum 0 September 27, 2005 08:35
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 04:34
