Locating particles in airblast atomization (DPM)
Old   May 17, 2004, 05:12
Default Locating particles in airblast atomization (DPM)
Prasad Dudhgaonkar
When using airblast atomization model in Fluent 6.1, in some cases, we have noticed that a very few particles are located (sometimes even 20% of the input) and that too they are not located all round the annular surface which is specified by (x,y,z), normal vector, inner and outer diameter. How does this affect the correctness of solution? And does it mean that the flow takes place only from the places where the particles are located successfully?
Thanks in advance Prasad
Old   May 31, 2004, 21:43
Default Re: Locating particles in airblast atomization (DP
kulwinder
I think you should correctly initialize your droplets. what I get from your message is that some of the streams are getting initilized where as others are not and i dont think that fluent will redistribute mass distribution among the streams that are initialized....
If you are trying to initilize droplets on some boundary then Fluent gives error. what you should do is to initialize droplets inside the domain say by a distance of 0.0000001 m.
good luck kulwinder
DPM: UDF - loop over all particles chris Fluent UDF and Scheme Programming 31 June 17, 2020 05:52
Injection of specific number of particles in DPM DH FLUENT 12 March 16, 2016 21:04
Constant & independent velocity for DPM particles Wikie Fluent UDF and Scheme Programming 1 September 23, 2010 05:35
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 11:58
DPM - Why do the particles not vanish? Johannes FLUENT 12 July 6, 2007 11:19
