starting fluent under freeBSD4.9
Old   June 2, 2004, 09:05
Default starting fluent under freeBSD4.9
Herakles
Hi!
I am using Fluent6.1.22 on a FreeBSD4.9STABLE machine in the university. I installed it correctly and am able to start the GUI of Fluent, but only with an error message, that looks like this:
 freebsd# fluent /usr/Fluent.Inc/bin/fluent: /sbin/lspci: not found /usr/Fluent.Inc/fluent6.1.22/cortex/lnx86/cortex.3.5.6 -f fluent (fluent " -path/usr/Fluent.Inc")
As said above, Fluent starts anyway!
When asked the following within the started GUI
 version
and I enter for example "2d", the response is the following:
 Starting exec [...] Error:cortex received a fatal signal (SEGMENTATION VIOLATION) Error objekt: ()
Error:there is no active application Error Object: (grid valid?)
Does anyone have any suggestions about how to solve my problem? I would be very pleased to get this fantastic program running on this machine right in front of me!
Thanks in advance, Herakles
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 06:47
Starting Fluent on multiple machine diamondx FLUENT 0 July 22, 2011 16:41
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
