Gambit problem: reading the nodes
Old   June 8, 2004, 12:49
Default Gambit problem: reading the nodes
Li
I have a file with all the nodes in the format of x y. How can I read it as a meshed grid using gambit? I have to keep the node information. That's why I don't want to generate the geometry and mesh it with gambit. Any comment will be appreciated.
Old   June 9, 2004, 16:10
Default Re: Gambit problem: reading the nodes
George
I'm not sure you can do this. You can look into the UG for formatting of mesh files though. Yoou see, for Fluent it is not only important to know the nodes, but also their neighbours and some other geometrical specifications, which are not contained in the node coordinates alone.
Regards
george
Old   June 10, 2004, 13:20
Li
Thanks a lot, George. I wrote a small program to read the coordinates of the nodes and write them into a neutral file as well as the neighboring information as you said. Since my grids are structured rectangular grids so that it's easy to figure out the neighboring relation. It looks good when I read the neutral file into Gambit.
Fluent 6.3 / Gambit 2.3.16 / Exceed 11 problem on Win7 pdilly FLUENT 23 April 2, 2016 12:10
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 02:33
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
problem importing mesh into gambit tsm554 FLUENT 7 December 3, 2010 22:15
Problem importing iges file to Gambit Tassos FLUENT 0 May 7, 2008 04:28
