June 16, 2004, 02:52 |
information about size function
hi
i have question which is a general question about what is behind the grid generation with gambit, especially in the following case: if i want to study the flow over a rectangle, i draw the rectangle then another one bigger. then i substract. i meshed the small rectangle (only edges) with a size 0.01. i meshed the edges of the bigger one with a size 0.1. then i mesh the surface. i see that the grid is thiner around the small rectangle and bigger and bigger away. i would like to know if gambit is using a size function "in deaulft" to create that mesh? what is the difference with using the size function? thanks for all yann |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
Droplet Evaporation | Christian | Main CFD Forum | 2 | February 27, 2007 06:27 |
