error with fluent for 2ddp
Old   June 15, 2004, 04:30
Default error with fluent for 2ddp
yann
hi
i made a 2D model of a kind of aerofoil with gambit. i am trying to see the flow over the aerofoil. i created a boundary layer on the skin and mesh the the rest of the space in triangle. when i run fluent and try to refine my grid in region i have a "warning: non positive volumes exist". it is a little bit odd considering the fact i was working in 2ddp. anyway, the refining is accepted, so i go on. when i run the iterations, i have the error: "divergence detected in AMG solver: pressure correction". can someone tell me what does it mean? and how to solve this.
thanks for all yann
Old   June 15, 2004, 11:02
Default Re: error with fluent for 2ddp
kpodila@dal.ca
Hello Group, Even I face this. Could u please know how can it be cleared? Thanks
Old   June 15, 2004, 11:03
Bob
You get the error due to non positive volumes. This must be corrected before you can run your case. If you saved your case after you refined it and got the non positive error then you will have to start over unless you have the pre-refined case saved.
Old   June 15, 2004, 14:15
kpodila@dal.ca
what are those non positive faces? fow can one get rid of them? Are u ure AMG error is due to grid?
Old   June 16, 2004, 10:06
Bob
My experience is that once they are there you can't get rid of them no matter how much refining you do. So you must go back to the last saved mesh that didn't have non-positive faces and use that one. What has happened most likely and I found this on the fluentusers.com page is that the boundary layer you created and the mesh have overlapped due to refining. Also if you read in the tutorials it states that if you have non-positive faces or volumes you must resolve the issue and if you don't FLUENT cannot begin a calculation (page 1-6 FLUENT 6.0 tutorial manual).
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
