I'm using dynamic mesh, but in the mesh motion preview fluent tells that a negative volume is detected. Please help me because my work cannot start. Thanks
Did you check your mesh??? Do you have no left handedness faces as per fluent definition.... If you' have some problem in mesh generation you should be able to check that in Fluent after importing the mesh. What kind of dynamic mesh problem are you solving??? Is it uniformly deformed or ????
Thanks, AJ |
I have check the grid and there is no problem, I have a wall that moves and an interface and another wall perpendicular to the first wall that are deforming zone, I'm simulating the passing of a train in a gallery.
How can I check the handedness of my grid? I can tell you that after the first updating, when a negative volume is detected, some left handed an right handed faces exist. Thank you AJ (I don't think really to understand what is the handedness) |
just try with a small time step. I guess u r using structured mesh.
Mahesh |
Dynamic Mesh on Pintle type injector. | herntan | FLUENT | 16 | September 4, 2020 08:27 |
pls help. mesh collapsed with dynamic mesh. | wlt_1985 | FLUENT | 2 | May 7, 2020 10:42 |
Incylinder dynamic mesh with volumetric reaction | mas | FLUENT | 4 | May 3, 2012 10:22 |
dynamic mesh on a hexa grid | Manoj Kumar | FLUENT | 0 | August 21, 2007 07:41 |
Dynamic mesh + grid adapt = Crash! (Files included | BillH | FLUENT | 4 | July 24, 2007 15:31 |
