July 19, 2004, 08:46 |
VOF model iterations not responding
After problem modeling and completing 20 time steps the program doesn't respond to any actions (experienced on 2 different PCs). I am doubtful about the turbulent dissipation rate and turbulent viscosity. The problem is a basic air-water model like the Bowl tutorial but no rotational movement. There is a translational velocity of air above still water.
What should i do to fix this and convergence?Thanks. |
July 21, 2004, 06:03 |
Re: VOF model iterations not responding
What if, if you decrease the time step?
regards özgür |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 16 | March 4, 2017 08:30 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
