how to capute the GUI
Old   August 12, 2004, 10:48
Default how to capute the GUI
SAM
i need to put the images and GUI :---> like the boundary condtion diologe box, i want to get the hard copy of this box dont tell me about the procedure of caputring the graphics display window which is used for displaying the coutours and vectors.
regrads Sijal Ahmed Memon
Old   August 12, 2004, 12:03
Default Re: how to capture the GUI
SAM
Old   August 12, 2004, 12:18
Alex Chirokov
One way to capture everything that on the screen is to press "Print Screen" on the keyboard. This will copy whole desktop image into the clipboard. So make sure you can see what you want to capture (GUI dialogs, vector, contour plot -whatever), press this key go to your image editing software (Paint Shop, PhotoShop, Paint Brush ..etc.) and crop the image. If you press ALT+"Print Screen" you will only capture active window. You can also use dedicated capturing software like "SnagIt" . Hope this will answer your question.
Old   August 12, 2004, 13:00
SAM
ohhhhhhhhh I cant believe it. it is working thanks a lot , u have solved my problem , which remained my problem for 8 months thanks again
TUI Commands from GUI? Carlos FLUENT 6 May 22, 2013 18:05
Defining Multiphase by text and by gui = different result and Segmentation Violation RPJones FLUENT 0 June 9, 2009 16:24
User Defined GUI Frederik FLUENT 0 June 23, 2006 16:12
Command Line vs. GUI Menus Go FLUENT 0 June 8, 2005 16:05
GUI window settings cmv Siemens 0 February 7, 2005 06:22
