Cannot preview mesh motion!
Old   August 17, 2004, 23:44
Default Cannot preview mesh motion!
dvinh
Hi all, I'm modeling a 2D airfoil which is hamornically moving up and down. An UDF is written to apply the motion to the the airfoil. All the internal grid surrounding the airfoil are modeled as deform zone with Spring-based Smooth and Local Remeshing Update methods. Time step size is 0.003125. When I previewed the motion, it worked for about 2-3 time steps and then it came up with Non-positive volume exits. I have tried with many Spring-factor and Boundary relaxtion method but it doesn't work. I'm wondering that is the problem has been set up in the right way? So I hope you guys can give me some hints if you have the same problem or any experiences with this problem. I'm looking forward to hear from you guys soon. Thank you very much. Nguyen Duc Vinh
Negative Volume during Mesh Motion Analysis giov_ingr FLUENT 2 December 13, 2013 06:09
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Help with Mesh motion preview Mustafa Ayad FLUENT 2 January 20, 2009 22:40
Mesh motion Hex cells vs tets kev4573 OpenFOAM Running, Solving & CFD 6 December 13, 2007 14:37
