NEED CONFIRMATION
Old   August 20, 2004, 08:25
Default NEED CONFIRMATION
Tania
I would like to know if the values of the forces in Report --->forces, depend on the references values???
I know that the refences values are used for the forces COEFFICIENTS (drag or lift..) but I am not sure about the FORCES.
thanks !!
Tania
Old   August 20, 2004, 09:19
Default Re: NEED CONFIRMATION
Jason
Only in 2D... You define a model depth in the reference values window and it will multiply the 2D forces by this depth.
Jason
Old   August 20, 2004, 09:41
Tania
So, you mean that in 3D (I am modelling a propeller) the references values are not used to calculate the forces
Old   August 20, 2004, 13:41
Jason
They won't effect your forces in 3D. Fluent integrates the local pressure and viscous forces over the area they act on to calculate your loads. In 2D, the results are Force/unit length, but most people don't think in those terms so Fluent multiplies the results it calculates by the depth that you input in the reference values window.
Easiest way to figure it out would be to solve the model and calculate the forces. Then change all the reference values to 1, or 50, or anything for that matter, and recalculate the forces to see if they change. They won't, it will only change the coefficients, but its an easy way to double-check if you want to make sure.
Good luck, Jason
Old   August 20, 2004, 15:04
Tania
Jason, Thanks a lot, every thing is clear
Best regards,
Tania
Incorrect Drag Coefficients / Mesh Confirmation w-nicholson ANSYS 3 May 18, 2011 12:00
Confirmation Needed on fvMeshSubset and Moving Meshes ngj OpenFOAM Programming & Development 1 September 17, 2010 08:06
Confirmation needed about calculation of divergence Pascal_doran OpenFOAM Post-Processing 1 June 11, 2010 02:41
Convergence confirmation Irfan FLUENT 3 November 24, 2002 00:54
convergence confirmation Irfan Main CFD Forum 1 November 19, 2002 05:05
