fluent warning
Old   May 16, 2007, 00:15
Default fluent warning
thandavan
Dear all, I am getting the following warning while initializing my problem.
"Attempted to correct face handedness of 20260 faces out of total 47385".
Can anyone tell me what is this error.??
Thank you
Thandavan
Old   May 16, 2007, 10:57
Default Re: fluent warning
sv
It means that the normal of some of the faces is not right. There is a simple text command you can use to fix the problem Type this in the text interface of Fluent and it will help. grid/modify-zones/repair-face-handedness
Old   May 19, 2007, 06:00
thandavan
Thank you very much friend
Thadavan
thandavan
Thank you very much friend. but while initilizing again the error is coming
Thadavan
Old   April 12, 2010, 01:19
Default sir how can i approach text interface on fluent
sridhar
sridhar.d009 is on a distinguished road
Originally Posted by sv
;141641
sridhar.d009 is offline   Reply With Quote
Old   April 12, 2010, 01:30
Default Attempted to correct face handedness
sridhar
is ur problem solved or not if it solve can u explain solution.i m also facing same problem
Old   November 4, 2010, 01:58
Sanghyun.LEE
Shlee is on a distinguished road
i also faced same problem
i think this problem cause by interface mesh
if u face the same problem, regenerate the interface mesh
Shlee is offline   Reply With Quote
How to use setField to create sphere sega OpenFOAM Pre-Processing 38 January 13, 2022 00:39
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 05:19
