September 19, 2004, 20:08 |
question about fluent
Is any one know how to use periodic moving wall boundary condition in Fluent? Thanks!
September 19, 2004, 21:52 |
Re: question about fluent
I am having the same problem. I think you will have to define a UDF for that. You can refer to the DEFINE macros section in the Fluent online help ( I think it is the sixth chapter- in the UDF manual section).I think it is called DEFINE_CG_MOTION! I hardly understand what's going on there, if you understand let me know. Thanks |
September 20, 2004, 10:34 |
Thank you for your idea, but how I can find the help file?
September 20, 2004, 10:43 |
Fluent Documentation dynamic mesh programming. Look at the separate udf manual about define cg motion, or better at the tutorial about dynamic meshes, this with the valve. If you are not familiar about programming, you have to learn about c++ (a few things) and about udf capabilities. Hope this helps.
September 20, 2004, 11:26 |
I do not have this Documentation about dynamic mesh programming. Anyone can give help on this? Thanks!
September 20, 2004, 21:42 |
September 20, 2004, 23:11 |
Thank you very much!
Question about modeling an elastic wall in Fluent | Mosheraa | FLUENT | 2 | June 24, 2011 18:47 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
Question: BC openFOAM vs. FLUENT | oehmu | OpenFOAM | 2 | December 14, 2010 16:14 |
a question about the liquidus temperature in fluent | hunter | FLUENT | 0 | April 13, 2009 21:55 |
General question regarding Fluent 6.3s mesh motion | AndyRoth | FLUENT | 0 | December 8, 2006 12:01 |
