Can I use UDF for this DPM?
Old   September 20, 2004, 13:13
Default Can I use UDF for this DPM?
Ilias
Hi! Can I define the burnout stoichiometric ratio in the combusting material properties, using a UD function? In the materials panel, constant ratio is preselected, so I suppose that a variable ratio could possibly be selected, but how I hook it there? (it is not a DPM property!)
Old   September 20, 2004, 13:40
Default Re: Can I use UDF for this DPM?
Ilias
In the materials.h there is a property named "PROP_burn_stoich". Which macro should I use to change its value?
Old   September 21, 2004, 05:35
Default ANSWER
Ilias
When I used MATERIAL_PROP(P_MATERIAL(p),PROP_burn_stoich)=1.9; where p= Tracked particle it worked. I call the macro in a custom law.
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT subhankar_bhandari FLUENT 0 August 19, 2010 03:01
please help me. i have question about the UDF at the DPM motallebi FLUENT 0 July 6, 2009 11:27
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
DPM with UDF - Step-by-Step Procedure???? Prashanth FLUENT 3 April 3, 2009 17:45
DPM - UDF for fluctuating bubble size Jaroslav Kotara FLUENT 1 April 19, 2006 09:02
