Orifice meter
Old   October 1, 2003, 09:16
Default Orifice meter
Murali
I am have been doing simulation of Flow in Orifice meter. The discharge coefficient I get using Fluent for Re of 40000 is around 0.66. The actual discharge coefficient is around 0.61. I tried refining the grid in the shear layer and modifying the solver, but I couldnt get it below 0.65.
Any help would be greatly appreciated.
Regards Murali.
Old   October 9, 2003, 07:03
Default Re: Orifice meter
mateus
Hi!
You have a very low Re number. What turbulence model are you using?
You shoul also know that cfr (RANS) will usually not give you exactly the same reults as experiment. What you should worry about is if your reults have the same trend as experimental ones (offset between cfd and experiment is very common)
Best regards
MATEUS
Old   November 14, 2009, 14:04
Shefali
shefali is on a distinguished road
Hi
I am also trying to verify the orifice meter problem (with pressure tappings located at D length units upstream and D/2 length units downstream using IDEAS-ESC software. I also overestimated the Cd by 0.07 (I got 0.68). When I am trying to refine the mesh, I am getting an error saying
"Fatal Overflow in linear flow solver".
How to address this problem?
shefali
shefali is offline   Reply With Quote
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Need help on simulation of incompressible flow in an orifice meter mep10jl FLUENT 0 November 18, 2010 19:25
lenght and number of nodes for an orifice meter flow problem - k-eps model fofo FLUENT 0 November 15, 2009 03:49
Flow past orifice aurel Main CFD Forum 0 January 27, 2009 06:46
Orifice Flow Prateep Chatterjee FLUENT 4 February 23, 2001 14:59
