radiation and symmetry
Old   November 3, 2004, 21:42
Default radiation and symmetry
Mark
I have recently begun to investigate modelling a very simple laminar flow with a symmetry boundary (flow between two parallel plates - symmetry is halfway between the two plates and parallel to them). I am concerned about using this symmetry boundary, however, because I am using a radiation model as well. When I model the entire flow I notice a drastically different temperature profile than when I use the symmetry boundary. The dominant mode of heat transfer is radiative. Does anyone have any experience with symmetry and radiation?
Thanks, Mark
Old   November 4, 2004, 13:09
Default Re: radiation and symmetry
Evan Rosenbaum
We have had no problems using radiation and symmetry, including axisymmetry, but it may depend on which radiation model you are using. We typically use DTRM or DO. Are you using one of these two?
Old   November 4, 2004, 13:50
Mark
I am using DO. Mark
error radiation model monte carlo andro Main CFD Forum 1 February 2, 2012 09:20
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
Incident Radiation Nicki CFX 1 April 17, 2009 08:18
Radiation and Symmetry Eric Main CFD Forum 3 June 3, 2004 07:30
Radiation and symmetry Eric FLUENT 2 May 31, 2004 11:02
