December 12, 2004, 14:14 |
temperature error
temperature limited to 5.000000e+03 in 26 cells on zone 3 in domain 1 temperature limited to 5.000000e+03 in 80 cells on zone 4 in domain 1
Inspite of the above, I am getting convergence in my model. Are the results given by my model correct? |
December 13, 2004, 17:31 |
Re: temperature error
FLUENT, as many solvers, has limiting functions to try to keep stable the solution. The result can be correct if the temperature in the real case doesn't reach the value imposed by the limiter, while it isn't correct if the temperature could reach that value.
Usually it should be better to avoid the limitation by properly setting the solver according to your peculiar case. Hi, ap :-D |
CGNS Compiling | Diego | Main CFD Forum | 17 | December 21, 2014 01:40 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 20:11 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
[Netgen] Installation of Netgen in SuSE Linux 92 | edvardsenpriv | OpenFOAM Meshing & Mesh Conversion | 23 | January 16, 2009 06:12 |
