K-Epsilon troublesome
Old   December 10, 2004, 08:19
Default K-Epsilon troublesome
Brenda
I am simulating a fully turbulent flow inside a bifurcated pipe with the K_Epsilon model and Near wall equilibrium Function.
But I have noticed after doing the balance of Mass and Total Energy that the total energy is not conserved. Moreover there is a great amount of total energy created inside my domain.
What is happening? Why?
Thanks in advance.
Old   December 10, 2004, 09:57
Default Re: K-Epsilon troublesome
se
Are you sure about the way you looked at the energy conservation? Have you counted everything? Borrowing the analogy of sugar cubes I read about in a thermodynamics book, have you counted the sugar cubes that your child ate and ones he threw out of the window? More possibly, by any chance, is your conclusion based on the observation that the total energy (or total pressure) locally (at some cells) exceeds the averaged inlet total energy (or rpessure)? If you are, you're not correctly understanding what the energy conservation is about.
Old   December 10, 2004, 15:42
Brenda
I have checked it with Fluent. It gives you the surface integral along inlet/outlet sections:
Mass Flow Rate (kg/s) -------------------------------- --------------------
inlet 17.340075
outlet_primary -17.250082
Net 0.08999189
Mass-Weighted Average
Total Energy (j/kg) -------------------------------- --------------------
inlet 180861.2
outlet_primary 182157.09
Net 181507.45
That's what I obtained.
Old   December 10, 2004, 16:04
se
You haven't counted the sugar cubes your children ate.
Old   December 14, 2004, 14:39
Brenda
Maybe I haven't count how stupid you are.
Old   December 14, 2004, 20:03
se
This is a little too harsh for someone trying to help you My apology if I annoyed you. Maybe I should've been more direct.
What I was trying to say was that you did not count the work done by the fluid against wall-shear and volumetric dissipation of energy, which drains the energy from the flow. You counted the energy-in and energy-out only. Checking conservation of "conserved" variables is a good idea. However, please keep in mind that the velocity field obtained by solving the momentum equations does not necessarily conserve energy unless you solve the equation for total energy.
Old   December 15, 2004, 11:22
Brenda
Thanks, I like that very much. Sorry for my last reply.
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
How to get reference to k and epsilon in the epsEqn and kEqn cfd_explorer OpenFOAM Programming & Development 0 March 10, 2011 10:16
How to get reference to k and epsilon in the epsEqn and kEqn cfd_explorer OpenFOAM 0 March 10, 2011 09:58
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
