ystar and yplus
Old   December 16, 2004, 09:33
Default ystar and yplus
sarah_ron
Posted By: Abhijeet Vaidya <vabhi@hotmail.com> Date: Tue, 29 Oct 2002, 10:25 a.m.
hi friends,
You must be aware of ustar & yplus as fluent defines it ! Going by their definitions , I was thinking that they should be exactly same if ystar is > 11.25. But when I solved turbulent flow over an expanding channel (pl note that this is a benchmark problem for laminar flow so the geometry of this channel must be familier to the readers), then yplus goes to zero at the reattachment poing which is obvious but even in the regions where ystar is > 11.25 , there is difference in the value of ystar and yplus which means that even when ystar > 11.25, still u_tau = (cmu^0.25)*(tke^0.5) does not hold ? But theory says otherwise ! Can somebody help ?
Old   December 16, 2004, 11:19
Default Re: ystar and yplus
me
They should be close to each other in equilibrium boundary layers where u_tau =(Cmu^0.25)*tke^0.5 is a good approximation. In non-equilibrium flows (e.g., diffusers you're considering), however, they can be quite different. A quintessential example is reattchment or stagnation point where u_tau and therefore y+ vanishes (tau_w = 0), yet TKE has a finite, usually quite large value there making ystar finite.
Macros for yplus, ystar, Ustar Seppl Huber FLUENT 6 October 12, 2020 04:26
Yplus and ystar guido_adriaensen OpenFOAM Post-Processing 17 April 21, 2019 03:44
yPLUS vs. ySTAR bastil OpenFOAM Bugs 1 March 14, 2012 04:00
How to access yPlus in UDF Alexander FLUENT 0 March 14, 2008 12:09
ystar and yplus sarah_ron FLUENT 2 July 4, 2005 10:51
