December 21, 2004, 13:37 |
limited turbulent viscosity
Hi all and happy hollidays: My problem is this : --Step 1: helium gas injection during 1 mn into a large cylinder filled with air at atmospheric pressure. The model is turbulent,compressible, time step 0.1 s. --Step 2: Stop helium injection and monitor helium equilibrium with air inside the cylinder during 250mn. During this step, along with the residuals , I monitor the average facelet velocity. For the fisrt few sconds , eveything was fine, afterwards, I have this message displayed : TURBULENT VISCOSITY LIMITED TO VISCOSITY RATIO OF 10E5. I changed the time step from 0.1s to 1s to 5s to 10s and I still have this message displayed. Am I doing something wrong, should the underrelaxation factor be pretty low or should I set an even bigger time step. Thanx for your help
reversed flow at pressure inlet and turbulent viscosity is limited.... | cfdiscool | FLUENT | 10 | June 10, 2015 06:15 |
turbulent viscosity limited to viscosity ratio of? | mechfloeng | FLUENT | 4 | February 6, 2014 12:45 |
Turbulent viscosity limited to viscosity... | Cyril | FLUENT | 16 | October 4, 2007 06:12 |
Turbulent viscosity limited to viscosity ratio... | Cyril | FLUENT | 8 | February 7, 2006 20:34 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
