programming fluent
Old   January 14, 2005, 07:41
Default programming fluent
pieizquierdo (miguel)
how can I set up a programm to leave fluent working alone?
where can I find information on this?
is this GUI?
Miguel
Old   January 14, 2005, 09:04
Default Re: programming fluent
Chris Bailey
Look at the User Guide chapter on the Text User Interface to see how to write programs (journal files) for the Text Menu System / Text Prompt System, or for the Scheme interpreter. Does that get you what you want?
Hint: you either write a series of simple commands for the TMS/TPS, or else you write a more complicated program in Scheme (a general purpose language derived from Lisp), and you use the command ti-menu-load-string to pass strings as commands to the TMS/TPS.
Old   January 14, 2005, 10:29
Thanks Chris
I had a look at it and it seems it is what I needed. Comprehensive reading starts now.
cheers
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 06:47
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 11:55
scheme programming in Fluent Wenbin FLUENT 2 November 27, 2003 13:49
