Doubt about F_FLUX(f,tf) macro & VOF ?!!!!!!!!
Old   May 7, 2007, 09:08
Default Doubt about F_FLUX(f,tf) macro & VOF ?!!!!!!!!
asghari
Hi
I have doubt about using this macro: F_FLUX(f,tf)
In the faces and in VOF two phase model , I use a UDF for proving that wether following relation is right or wrong:
D(rho)/D(t)+sigma on faces(Fe+Fn-Fs-Fw)=little value (in converge conditions)
But I sure F_FLUX(f,tf) isn't suitabe for this case(two-phase); I check this UDF in single phase ; results were quiet correct. I present UDF as follows:
/************************************************/ #include "udf.h" /* must be at the beginning of every UDF you write */
#include "mem.h" /* must be writen for accessing to memory */
#include "sg.h" /* needed for secondary gradient macro */
#include "flow.h"
#include "sg_mphase.h" /************************************************** */
DEFINE_ADJUST(my_define_adjust, domain) { /**beginig of define_adjust**/
Thread *tf;
Thread *t;
face_t f;
cell_t c,c0,c1;
real physical_dt,flow_time,convection2;
if(!Data_Valid_P()) return;
physical_dt = RP_Get_Real("physical-time-step");
flow_time= RP_Get_Real("flow-time");
thread_loop_c (t,domain) {
begin_c_loop(c,t) {
C_UDMI(c,t,0)= C_UDMI(c,t,1) ;
C_UDMI(c,t,1)= flow_time;
if(fabs(C_UDMI(c,t,1)-C_UDMI(c,t,0))>1e-10) /*(i.e if(C_UDMI(c,t,1)/=C_UDMI(c,t,0)) ( for discovering of :Is time step new or not? )for geting of density and anthalpy from last iteration in previous time step(dt=3e-7.0)*/
C_UDSI(c,t,0)=C_UDMI(c,t,2) ;
C_UDMI(c,t,5) = (C_UDMI(c,t,4)/C_VOLUME(c,t)+C_UDMI(c,t,3));
/*UDM for indirect accessing to mass imbalance in each cell*/
C_UDMI(c,t,2)=C_R(c,t);
end_c_loop(c,t)
/*****beginning of Calculation of mass imbalance*****/
begin_c_loop (c,t)
C_UDMI(c,t,3)=(C_R(c,t)-C_UDSI(c,t,0))/ physical_dt; /*unsteady term in continuity equation*/
} /*end of computing unsteady term*/
end_c_loop (c,t)
begin_c_loop(c,t) { /***15****/
int i=1 ;
C_UDMI(c,t,4)=0.0 ;
c_face_loop(c,t,i)
f = C_FACE(c,t,i);
tf = C_FACE_THREAD(c,t,i);
if(BOUNDARY_FACE_THREAD_P(tf))
convection2 = (F_FLUX(f,tf));
else if(F_C0(f,tf)==c)
else
convection2 = -(F_FLUX(f,tf));
C_UDMI(c,t,4) = C_UDMI(c,t,4)+(convection2);
end_c_loop(c,t) }
/**end of define_adjust**/
You can compare C_UDMI(c,t,5) with real mass imbalance in Display-->contours--->residual--->mass imbalance panel . discrepancy is clarified. Has anybody suggestion about improving of this UDF to take logical results for face fluxes?
For running of UDF, please turn off UDSI solution .
Thanks in advance for any help.
Asghari
Old   May 20, 2007, 11:51
Default Re: Doubt about F_FLUX(f,tf) macro & VOF ?!!!!!!!!
MikeWolf
f_flux in interior seems to have a unit of kg/m2-s, which is needed to multiply Area.
Old   October 28, 2012, 03:03
Leon Chen
759599290 is on a distinguished road
Hi @MikeWolf:
i have some problems with what does F_FLUX(f,tf) return in UDF, but i have done some tests, which showed that F_LUX is not equal to vec(velocity) dot vec(face area). so I am really puzzled, hope for your help.
759599290 is offline   Reply With Quote
HELP! adding a mass source to VOF eqn. by UDF??? ROOZBEH FLUENT 5 December 3, 2016 17:53
INTRODUCE A MACRO FOR AVOID SMEARING IN VOF in ccm+ lupoigloo STAR-CCM+ 1 March 11, 2010 10:52
Doubt Regarding macro calculator option in CFX Sridevi CFX 0 December 21, 2005 03:55
another VOF doubt some1 Main CFD Forum 6 April 16, 2002 06:52
Doubt on VOF some1 Main CFD Forum 12 April 6, 2002 14:18
