I G. S. G. Ravikanth have been using FLUENT 6.0 to solve the flow through an engine room. The engine is fitted with a radiator and a fan blows air onto it. I am having difficulty in modeling the engine radiator. I have tried to simulate it as a porous surface. But i am unable to get a meaningful result. -What are the parameters needed to model a porous surface? -Can the radiator be modeled as a porous surface, or is there any other means of doing that?
I would be very thankful to you, if you can help me in solving this problem. |
Problem in setting porosity region for rhoPorousSimpleFoam | run_cfd | OpenFOAM Pre-Processing | 1 | May 31, 2011 09:02 |
Porosity field in Fluent | wojciech | FLUENT | 1 | September 20, 2010 11:19 |
UDF for porosity | Giacomo | FLUENT | 3 | July 23, 2007 09:23 |
porous media with variable porosity | Kevin A. | FLUENT | 3 | December 24, 2006 10:56 |
Media with low porosity | Emmanuel Resch | Siemens | 0 | September 29, 2006 12:44 |
