GRADIENTS
Old   January 28, 2005, 05:24
Default GRADIENTS
Luca
Hi all! I have a problem with gradients. Why using the coupled solver it's not possible to obtain the gradient? The solver gives me a segmentation error but gives no problem If I want to know the reconstructed gradient of the pressure. Please help. I hope somebody can gimme some suggestion. Luca
Old   January 28, 2005, 10:38
Default Re: GRADIENTS
gts
I had a similar problem. Are you shure that you use: solve/set/expert and "yes" answer to the question Keep temporary solver memory for beeing freed?
see UDF manual, pag 5-10
Old   January 28, 2005, 10:43
Luca
Yes I'm sure. Anyway I noticed the it works even if I don't set yes...it's strange, isn't it? I discovered that some gradients can be found, some others not...This happens even when I set the segregated.
Velocity Gradients or Pressure Gradients? owayz OpenFOAM 9 August 14, 2012 13:09
Large pressure gradients = anisotropy??? cfd_enthusiast Main CFD Forum 0 February 9, 2010 11:09
density gradients in CFX post prabhu CFX 1 June 12, 2006 06:47
extract velocity gradients with cfx4.2 franco belosi CFX 1 November 28, 2002 18:41
Calculation of Gradients Bo Jensen Siemens 0 July 10, 2001 07:14
