February 6, 2005, 17:28 |
complex roughness pattern
In the new Fluent Beta Version it is possible to read in a profile file with roughness parameters for specifying the wall boundary conditions. I am not sure how to create this file. Has anyone done that yet and/or can help me? Thanks
February 10, 2005, 12:10 |
Re: complex roughness pattern
I dont' have that beta version of fluent but I guess you can export from fluent a profile file similar to the one you want to create.
After that look at the structure of the exported file with a simple ASCII editor (e.g. notepad) and try reproduce the same structure to a new file containing the roughness parameters you want to assign. Fluent should be able to import the file with the changed parameters. To make the procedure easier you can use different softwares like explorer, 123, mathcad, mathlab or others |
February 24, 2005, 21:45 |
Grazie mille, Giorgio It looks like this is the only possible way. It is quite time consuming with this big, complex surface I am working with, but it seems to work. Thanks again Tarnz
February 25, 2005, 04:55 |
Di niente Tarnz. I think you can find in the fluent website an usefull tutorial in which is used an udf that build your profile of bc in a easier way. I didn't use that udf but a student in my uni did it for a VOF model (air over water).
it will speed-up the implementation of your cases but it wont affect the numerical results regards, giorgio ps: at the moment i'm working on flow over complex terrains so it would be nice to compare some results. Don't esitate to contact me whenever you want |
nutRoughWallFunction and Surface Roughness Documented | AlanR | OpenFOAM Programming & Development | 64 | January 6, 2024 07:13 |
Laminar flow and wall roughness | junbbung | FLUENT | 2 | November 26, 2022 21:22 |
How to apply variabe roughness, e.g. to complex terrain? | Fridolin | OpenFOAM Running, Solving & CFD | 3 | August 12, 2020 15:09 |
NACA standart roughness | DAK565656 | Main CFD Forum | 2 | August 24, 2005 00:47 |
Roughness adaptation in CFX 4.4 | Bart | CFX | 1 | May 2, 2003 08:32 |
