Running unsteady problems in the background
Old   February 17, 2005, 17:59
Default Running unsteady problems in the background
Jie Cui
I can run a steady problem in the background by using a script file without any problem, but when I try to do the same thing for an unsteady problem, it doesn't work. It always treat the problem as steady. Is there something special I need to do in the script file so that Fluent understands that I want the unsteady solution. Thanks a lot.
Problems with Gambit running on windows xp pro Carlos Ruiz FLUENT 1 February 27, 2009 05:04
unsteady flow problems Daniel FLUENT 0 January 25, 2009 23:54
Problems of running the parallel computations lorraine FLUENT 17 July 6, 2007 08:08
problems for unsteady calculation olivier FLUENT 5 June 21, 2007 02:45
Problems on running cfx in parallel Nan CFX 1 March 29, 2006 04:10
