Rotating chamber
Old   February 23, 2005, 11:04
Default Rotating chamber
DS
I am modeling a flow through a rotating chamber of cylindrical shape. The axis of rotation is perpendicular to the direction of the rotating chamber. The side and the top views of the 3D geometry are shown in the figures. The asterix (*) represent a liquid outlet, which is located on the side of the chamber. The liquid inlet BC is velocity inlet (uniform velocity) and the outlet BC is outflow. A rotating reference frame is used.
Side view
axis of rotation (II), X interior
II
II=================
II=*XXXXXXXXXXXX=<--liquid inlet
II=================
II
Top view
II=XXXXXXXXXXXXX=<--liquid inlet
I have the folloving questions for CFD guys: 1. How to calculate frictional and static pressure drop(consequence of centrifugal force field) separately? (I am able to determine frictional pressure drop experimentaly and I would like to compare to CFD results.) 2. When I use outflow BC I get convergence and solution easily. But that is not the case with a pressure-outlet BC (backflow). Why? 3. I tried to use 2D geometry to reduce computational time and I also have problems with convergence and backflow (even with outflow BC)
Simulation is transient, flow is laminar. If more details are needed, please let me know.
I will be grateful for any answer. David
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 08:53
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
Combine non rotating part with rotating parts or not ? teck0516 Main CFD Forum 0 July 16, 2011 13:38
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 06:14
IcoDyMFoam how to define more than one rotating regions naoko_oyama OpenFOAM Running, Solving & CFD 0 November 14, 2008 08:25
