Mass flow inlet
Old   March 3, 2005, 04:25
Default Mass flow inlet
Anshul
I recently was modeling flow though a pipe, I had modeled the inlet with mass flow inlet boundary condition. Is there some other way of applying the same boundary condition, may be by using a spherical control volume outside the inlet.
anshul
Old   March 3, 2005, 10:06
Default Re: Mass flow inlet
Jason
I'm not entirely sure what you're shooting for, but if you're trying to get flow characteristics due to the inlet, a common way of dealing with this is to create a large area in front of the inlet (a plenum) and apply the boundary condition on the other side of the plenum. This also pulls the boundary condition away from your area of interest.
Try to model it as real as possible. You may want to switch to a pressure inlet to prevent the velocity from entering the plenum where it normally wouldn't.
Hope this helps, and goodluck, Jason
Old   March 4, 2005, 00:19
Anshul
Thanx Jason,
As I had told earlier, I am solving a problem in an air intake, the air comes at some specified mass flow rate and exits the domain through a series of outlet ports. So I wanted to know about the different ways to provide the inlet mass flow boundary conditions. One of my colleagues suggested using a sphere of about 3 times the inlet radius, outside the inlet face. Also is such care is required at the outlet also. I would be very grateful to you if you could tell me abt some references where I can read about proper modeling of internal flows.
thanx once again
Anshul
velocity calculations in mass flow inlet boundary condition montazer1012 FLUENT 1 October 18, 2010 03:11
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
2 Inlet Pres BC's and Out Mass Flow - Convergence SN Siemens 0 July 19, 2006 09:12
Mass Flow Inlet Pravir Kumar Rai FLUENT 0 February 19, 2003 14:03
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
