Is the flow turbulent?
Old   March 14, 2005, 10:00
Default Is the flow turbulent?
Katarina Tenti
how does one in a general geometry (not tube) decide before CFD calculations that the flow therein will be turbulent? I have a geometry that is far from being a pipe and I would not know how to calculate a representative Reynolds number therein.
Thank you for your help.
- Katarina
Old   March 15, 2005, 02:51
Default Re: Is the flow turbulent?
Melaku Habte
If I am not mistaken, wasn't hydraulic diameter for this purpose? If you have a non-circular geometry, you can obtain an equivalent diameter based on its geometry and then based on that diameter you'll calculate Re_no. There are also some other correlations if you have a particular geometry.
rgds
Melaku H
Old   March 15, 2005, 08:46
khalid sultan
Hi;
I would recommend "Michel method". For details see
(Viscous Fluid Flow) by: Frank M. White, 2nd edition, page 377 .
One more thing, eq.(5.38) in the above mentioned Ref., was later modified by another one which require some kind of iteration to be solved; to see this new form goto AIAA 2000-0048.
The above method could be easely implemented in any code -I assume !-
Hoping it would help
Old   March 16, 2005, 05:49
Katarina Tenti
Hello Melaku,
thanks for the response! I have a situation where I think that recirculation areas act as "walls" of a narrowing, through which fluid is squeezed. If I calculate the hydraulic diameter of the actual geometry, I will get Re that are below those that occur locally.
Thanks, Katarina
Old   March 16, 2005, 05:59
Katarina Tenti
Hello Khalid,
thank you, I checked out the AIAA paper, and am now waiting for the book to arrive.
Cheers, Katarina
spectrum: LES of a turbulent channel flow finally goes to turbulent liu OpenFOAM Running, Solving & CFD 6 November 1, 2011 01:00
Difference between recirculation zone and turbulent flow region ashtonJ Main CFD Forum 0 September 16, 2011 03:46
Patch a bubble inside turbulent flow Helmi FLUENT 0 February 4, 2011 04:54
Turbulent flow through hexagonal circular pipe yogesh@cfd Main CFD Forum 0 November 9, 2010 23:10
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
