UDS
Old   March 21, 2005, 11:27
Default UDS
David
I have some problem with my result and I think that the mistake may be in my UDS. The equation is the following differential equation: ݃/t=S. The source term may depend of temperature, pressure and . This equation is coupled with the continuity, momentum (x,y) and energy equations.
I calculated separetely ݃/t and S and I saw that these two quantities is not equal. Fluent is supposed to solve the UDS equation at the end of a time step after the momentum, continuity and energy equation. So I thought that there is may be a kind of numerical mistake like Fluent solve properly the four equations without the last one for the UDS.
I decided to simplify my problem and I decoupled my system of equations. I posed that my source term is a constant. In that case, the continuity, momentum and energy equations are coupled together and the UDS is alone (I wrote the transcient term to not be dependent of the density like in the documentation). I saw that ݃/t and S were not equal too.
First of all, I think that the UDS variable may be coupled in the others equations. If it is the case, I didn't see anywhere the information in the documentation.
Actually, I really don't understand and it is probably a misunderstanding in the way to solve the entire problem.
I think that ݃/t and S must be equal. What do you think about this fact? Could you send me any suggestions about this post? Salutation, David
Old   March 21, 2005, 11:31
Default Re: UDS
David
Sorry for the bad character. Just replace the following equation: ݃/t=S. by variation of density/variation of time = source term.
Salutation, David
UDS Flux Function Choice Yang Chung FLUENT 1 November 17, 2015 01:14
PEM modeling UDS diffusivity in mixture gemini FLUENT 6 August 7, 2012 07:37
fixed value in the domain for a UDS in case of multiphase flow swati_mohanty FLUENT 2 November 30, 2010 03:17
Doubts UDS Flux, UDS Unsteady for VOF model kel85uk FLUENT 0 March 17, 2010 08:53
A good question about UDS Z FLUENT 1 March 31, 2005 15:14
