about symmetry BC
Old   March 23, 2005, 10:51
Default about symmetry BC
sulfi
dear user,
if we use symmetry BC, should we have to double the forces to obtain the total force on the body.
expecting ur reply
sulfi
Old   March 23, 2005, 11:30
Default Re: about symmetry BC
Jason
Yes, in Fluent you have to double the force to obtain the total force when using a symmetry condition. The other option is that if you look at the force coefficients instead, use half of the reference area and that will give you a force coefficient for the entire model.
Just a side note, this topic has been discussed several times before on the forum. This is the same for many other topics. For a quick answer to your questions, search the forum and archives first. If you can't find what you're looking for, then post your problem.
Hope this helps, and goodluck, Jason
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
Properly using symmetry with both CFX and ANSYS workbench for a FSI analysis, help! Cirion0000 CFX 0 July 6, 2009 14:26
Forces in Symmetry Matt CFX 2 February 25, 2009 05:41
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 07:09
radiation and symmetry Mark FLUENT 2 November 4, 2004 13:50
