Problem with surface monitoring
Old   March 23, 2005, 12:49
Default Problem with surface monitoring
vitmalin
I've got a problem with monitoring of a large number of surface monitoring points. The matter is that I need to monitor temperature in 160 points with the time, but Fluent doesn't allow me set up more than 30 points in solve\monitor\surface\surface-monitors... After I defined 40 points and then press Ok, error messsage appeared "31-st monitor point is incompleted" and all the monitors after 30-th are blanked with grey color. Please help!
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Problem about a 2D surface rotation skyblue_mech Main CFD Forum 0 June 8, 2010 04:49
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Surface orentation problem in icemcfd jeevan kumar CFX 0 August 13, 2008 01:54
Problem with surface pressure integrals javier FLUENT 0 February 9, 2004 15:09
