Natural Convection over a vertical wall
Old   March 25, 2005, 11:40
Default Natural Convection over a vertical wall
Sireesha Pasari
hello all,
I am relatively new to using fluent, Kindly forgive me if i am wrong anywhere. I am trying to perform natural convection over a vertical thin wall (wall thickness = 0), and calculate heat flux along the wall surface, temperature variation and velociy distribution.
modelled as a box : left, top, right, bottom
this is how my boundary conditions are:
(units same as in fluent)
wall definied to the left wall properties: heat transfer coeffecient: 6.8085 calculated from nussles number and thermal conducivity and wall length, Free sream temperature:290K wall temperature = 310K
inlet at the bottom (pressure inlet): inlet temperaure = 290K
outlet at the top (pressure outlet) : backflow emperature 290K
symmetry defined to the right
wall lenghth: 0.04 m
operating conditions : gravity = -9.81
maerial properties (air)
density (bossique eq): 1.177 Cp = 1005 thermal conductivity (K) = 0.0267 viscosity = 1.845E-5 prandtl number = 0.69 -> calculated from alpha = 0.2216e-6 m^2/s, and viscosity = 16.84E-6 at 300K
I am aable to obain the curves for temperature and velocity, and theoritically they appear to be correct, but i am not able to obtain the heat flux (fluent gives me 0) i did not make any changes to reference values under report in fluent.
PLease help me, as I feel I am lost in this.
Thank you all in Advance
Sireesha Pasari
Old   March 27, 2005, 03:43
Default Re: Natural Convection over a vertical wall
dpshaka
you have not give a boundary condition on the wall .
my object is "numerical simulation of the natural convection of cylinder arrays in large and finite space ".
my prilimary simulation is the numerical simulation of the natural convection over a vertical flat withe isoflux and isomal boundary condition.
fluent give me excellent resulte when compared withe the benchmark solution.
i think the problem is your boundary condition of the wall.
i can not understand why you have give the value of h first.
Old   July 15, 2012, 16:31
Post
Shaon
Navid450 is on a distinguished road
I am a novice in the field of CFD. Anyway, my objective is " Numerical analysis of laminar natural convection over a vertical plate" . Can you help me in this respect?
Navid450 is offline   Reply With Quote
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Natural convection flow over hot vertical plate M.sridhar FLUENT 8 June 6, 2011 08:46
Natural convection over a vertical wall mimi FLUENT 5 February 3, 2008 20:05
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
