Floating point error: divide by zero
Old   April 3, 2005, 13:14
Default Floating point error: divide by zero
Chris
Hello guys,
I just tried to load up and work with already existing *.dat files but every time I try to display contourplots for example, I get one of the following error messages:
floating point error: divide by zero
Error: FLUENT recieved a fatal signal (SEGMENTATION VIOLATION)
I ran the simulation in Australia and had no problems on the Australian computers. Now I´m back in Germany, so I first supposed, it´s a setup problem, because English computers separate numbers with a point (.) and in Germany you separate with a comma (,). So I reset the setup without success.
Maybe you guys have any recommendations?
Chris
Old   April 15, 2005, 01:22
Default Re: Floating point error: divide by zero
fluidwork
Maybe something wrong with the driver of graphic card. There are some discusses about this in the forum. You can search in this forum. Also you can type: "fluent -driver msw" in the command window. Good luck!
Old   April 15, 2005, 02:33
chris
Thanks for your help,
it was the graphic card driver indeed. There were several little subprogramms to increase the power and speed. Since I disabled all of them, I´m working without problems.
Chris
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 16:34
block-structured mesh for t-junction Robert@cfd ANSYS Meshing & Geometry 20 November 11, 2011 04:59
Finished simulation doesn't start: floating point exception [Divide by zero] MaxCFD STAR-CCM+ 3 June 26, 2011 10:31
reactingFoam floating point exception pajofego OpenFOAM 0 November 6, 2010 17:29
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 02:27
