April 12, 2005, 09:13 |
MDM problem
When I performed the mesh motion in solve menu for MDM, I met the below message. What was wrong?? What should I do??
Error: Internal error at line 1595 in file 'grid.c'. replace_c_in_f: cell not found Error Object: () |
April 12, 2005, 10:11 |
Re: MDM problem
Can you show us your UDF? Maybe instead of looping on faces you should loop on cells.Luca
April 12, 2005, 10:23 |
Re: MDM problem
Oh, actually My UDF is really simple. It just is forced moving. So UDF is very simple.
#include "udf.h" DEFINE_CG_MOTION(stem, dt, vel, omega, time, dtime) { vel[1]=0.014; } Above is all, My UDF. Futhermore, when I tested it using mesh motion at first, there was not any error. |
April 12, 2005, 10:26 |
Re: MDM problem
Maybe you should initialize the omega vector...Actually I dont'know. Your UDF is simple...
April 12, 2005, 16:52 |
Re: MDM problem
Profile files are much easier for defining motion, once they are set up you don't have to reload them every time you restart Fluent.
As for your error, I'd suggest you contact Fluent support. Shuto. |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
