setting the working directory
Old   April 22, 2005, 13:12
Default setting the working directory
Jiri Novak
How can I change my default working directory under WIN-XP in order to more comfortable starting GAMBIT. In deffault settings it automaticaly offers to me 'C:\Documents and Settings\username', but I work in 'D:\username' directory and have to rewrite the absolute path each start of gambit.
Thank for help.
Old   April 22, 2005, 18:25
Default Re: setting the working directory
pUl|
Fool around with windows shortcut properties. If you want to use the gambit icon or whatever on your desktop, right click that icon -> properties -> "Start in" box and put your d:\whatever there.
Old   April 23, 2005, 02:23
Short
I know this should work but for me, it doesnt seem to. I still get a different 'working directory' which is many clicks away from where I want to be!
Any more ideas?
Old   April 23, 2005, 13:37
pUl|
Use the command prompt and start gambit from the command line
Old   April 24, 2005, 08:13
zxaar
going to that directory will be little trouble, but one can make a batch file to do that, that cd src_dir and gambit
and keep that batch on desc
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
change CFX working directory dklastiwka CFX 0 February 17, 2010 15:36
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
Installation problem with GCC Norma McKee (Mckee) OpenFOAM Installation 10 March 4, 2007 07:09
Gerris software installation mer Main CFD Forum 2 November 12, 2005 08:50
