Low Re Backward facing step
Old   April 11, 2005, 10:55
Default Low Re Backward facing step
Riaan
Hi guys,
I am currently modelling a backwards facing step at relatively low Re (<<1e-6).
I have tried the Realizable k-e model with non-equilibrium wall functions, but I am having trouble with convergence.
My Y+ values are of the order 1, since the step region is relatively small compared to the rest of the domain, and I need sufficient nodes to capture the flow features - so if I use a y+>30, I just don't have enough nodes in the region of interest.
Anyone have suggestions? I am thinking k-w SST model, since it should have a low-Re correction - but would y+ = 1 be good for this model?
Thanks! Riaan
Old   April 12, 2005, 02:49
Default Re: Low Re Backward facing step
Markus
Hi Riaan
Ever thought about a laminar flow regime at your Re ?
br, Max
Old   April 12, 2005, 17:50
Riaan
I doubt the flow will be laminar in the re-attachment region, or in the circulation region aft of the step.
Old   April 14, 2005, 03:21
Markus
I assume your Re of 1e-6 is based on inlet velocity and inlet cross section. I am quite sure that there is no transition to turbulent flow even in the areas you have mentioned. By the way, I think there is a FLUENT tutorial about your case, which highlights laminar and turbulent flow over a backward facing step.
Cheers
backward facing step erni FLUENT 3 November 23, 2011 13:49
Backward facing step using locDynOneEqEddy Tarak OpenFOAM Running, Solving & CFD 0 June 17, 2011 14:04
Turbulent flow over a backward facing step Jenner Main CFD Forum 1 December 2, 2006 11:21
Backward Facing Step Jimmy Main CFD Forum 3 July 25, 2004 22:37
backward facing step ryoga Main CFD Forum 1 March 9, 2003 02:52
