Fluent 6.2 NITA
Old   April 18, 2005, 16:06
Default Fluent 6.2 NITA
Steve
Has anyone used the non-iterative time advancing NITA scheme in Fluent 6.2 on LES computations? I have tried, the solution diverges after a few time steps each time I use the NITA scheme. The solution does not diverge using the ITA scheme. Any suggestions?
Also, has anyone simulated a simple open channel flow with LES?
Thanks in advance
Steve
Old   April 19, 2005, 05:02
Default Re: Fluent 6.2 NITA
edi ghirardi
NITA sucks. I've tested it for a simple slosh problem (more or less the same tank Fluent used to promote it on its site), but the velocity field had several peaks of magnitude absolutely unreal. The same problem run with non-NITA algorithm gave definitely better results. Edi.
Old   April 21, 2005, 02:21
zxaar
i also observed that NITA diverges with LES, i have switched back to iterative schemes, it takes time but does the work at least.
Fluent 6.2 & Gambit on Windows XP x64 AcoidanBM FLUENT 9 October 30, 2011 14:08
Where to find the difference between fluent 6.3 and version 6.2? legendyxg FLUENT 1 May 7, 2009 03:12
loading FLUENT 6.2 and GAMBIT on Red Hat LINUX Kiran FLUENT 1 October 16, 2007 09:12
Implementing own PDF in to fluent 6.2 and higher Paul FLUENT 0 August 6, 2007 10:47
Moving Dynamic Mesh in Fluent 6.2 R.M.Bharath Somayaji FLUENT 0 January 9, 2006 20:36
