Right & Left Handedness
Old   May 13, 2005, 08:49
Default Right & Left Handedness
Rajesh G
Hi Everybody
I am trying to generate meshes in a 3-d model of a valve. When I check the grids, its showing the error message as grid check failed. I have used the command "repair meshes" and 2 left handed meshes are reported to be converted into right handed meshes. After that my grind checking is found fine. But when I proceed the calculation, its giving the error message of negative volumes. Could anybody help me in fixing this problem?
thanking you,
Rajesh
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 06:25
Left Handedness after Y+ Adaptation Jim FLUENT 0 December 1, 2008 10:48
Right & Left Handedness Rajesh G FLUENT 2 May 15, 2005 08:38
