May 9, 2005, 21:34 |
Wall Y+
Hello all,
In order to increase the wall Y+ value, i did boundray adaption. BUT, the results turn out to be less accurate than without having the adaption. Which means, without adaption, my results is OK. What does this mean? Does it mean I dun have to decrease the value of Y+ even though in it quite high? Thanks. Sham. |
May 10, 2005, 11:15 |
Re: Wall Y+
Are you using Std Wall Fn or Enh Wall Tr?
May 10, 2005, 17:58 |
Re: Wall Y+
It is enhanced wall function.
Thanks. |
May 10, 2005, 18:38 |
Re: Wall Y+
What is your domain (geometry)?
May 11, 2005, 04:10 |
Re: Wall Y+
I have arectangular domain with a cylinder sitting on the bottom. It is about 66000 cells.
thanks. Sham. |
May 11, 2005, 11:02 |
Re: Wall Y+
You need Y+ of order 1-5. What is the value before adaptation?
May 11, 2005, 16:15 |
Re: Wall Y+
It is of the order around 1000. But I dunno how many times whould I adapt boundary to bring down the values to 1-5.
May 12, 2005, 01:01 |
Re: Wall Y+
Did you try placing your first grid point using http://geolab.larc.nasa.gov/APPS/YPlus/
May 13, 2005, 06:59 |
Re: Wall Y+
#9 |
can you pls tell me hwo can I do that in Gambit?
Sham. |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
