May 14, 2005, 09:52 |
How to active the turbulent models
How could I active the turbulent models that didn't exist in the list.Just like des model,les model.
May 14, 2005, 10:42 |
Re: How to active the turbulent models
CHeck the manual, You must be in 3D I think, if you want to activate LES.
May 16, 2005, 09:57 |
I don't think so,I have herad somebody have had defined 2D les....
May 16, 2005, 18:15 |
An excerpt from http://www.fluentusers.com/fluent61/...ug/node459.htm
!! The Large Eddy Simulation model is available only for 3D cases. |
May 16, 2005, 22:35 |
to activate les model in 2d
(rpsetvar 'les-2d? #t) |
May 16, 2005, 22:39 |
yes after this yopu have to go and check in viscous model panel to activate it
May 17, 2005, 00:22 |
interesting.
May 17, 2005, 02:28 |
actually lot of things are not given in fluent manuals, or they are not given at the place they should be given,
i found this out while doing an acoustic tutorial, quite and odd place to find how to activate 2d les model, |
May 17, 2005, 05:14 |
#9 |
hi,
can you tell me what exatly this is.I tried this in comand line .It didn't work. thank you balaji |
May 17, 2005, 05:47 |
#10 |
it should work, before posting the message i checked it then only i put it on forum,
further by this command u should eb able to see les models in viscous panel where u enable turbulence, so here when u check that option it calculates les model |
May 17, 2005, 06:43 |
#11 |
hi,
I don't know how to use this command.I put this in the command line. It came Invalid command[rpsetvar]. Thank you. |
May 17, 2005, 07:03 |
#12 |
which version of fluent u r using, and make sure that you are in 2d version of fluent (i have checked this fluent 6.1. and 6.2, and it worked fine)
May 18, 2005, 12:11 |
#13 |
I am using fluent 6.1 and 2d version. If Possible please send me a tutorial which explains about this command.It will be useful for me. Sorry for taking your time.
Thank you |
Laminar doesn't converge; Turbulent models do? | Amit | FLUENT | 11 | April 23, 2015 22:55 |
Two-equation turbulent models: low re airfoils | truffaldino | Main CFD Forum | 51 | March 19, 2012 18:57 |
Is this understanding of turbulence models correct? | 3kha | Main CFD Forum | 3 | January 31, 2011 21:31 |
Different turbulent models for the same material | John | Siemens | 1 | May 2, 2007 03:25 |
Laminar vs. Turbulent Models | Dahvid Brown | FLUENT | 3 | October 23, 2000 02:36 |
