Dear all, I am doing cfd analysis to find wind pressure on anattena. With inlet velocity 16.67 m/s, I got static pressure around 169 pa and total pressure 206 pa. What pressure shall I consider as force, which is really acting on antenna, whether static or total(static + dynamic). Please help me
static. Luca
Hi luca But why only static? why not total?
Because you're interested in loads, so you need to evaluate the difference betweeen local static pressure and free-stream pressure (coefficient of pressure).Luca
It sounds confusing to me. Isn't it should be total pressure? If only Load consideration then Static pressure is fine. But when it's about pressure force, then there should be total pressure, if the surface where the pressure force is to be considerred is perpendicular to the flow. Luca, can you clarify my doubt?
I have same problem but in the water. Since decembre I am looking for same answer. As I understand you should use static but you have to prepared so fine mesh in boundary to get in first layier dynamic pressure equal 0. please give me notice if you find some thing more?
Pressure force calculation in incompressible solvers | philippose | OpenFOAM Running, Solving & CFD | 10 | December 7, 2019 04:51 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Setup/monitor points of pressure and force coefficients | siw | CFX | 3 | October 22, 2010 06:07 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 17:19 |
Calculate Pressure force | andreis | FLUENT | 0 | May 16, 2005 05:40 |
