periodic source term!!
Old   May 19, 2005, 04:12
Default periodic source term!!
andre
Dear all,
I want to add a source term s=a*sin(w*t) to momentum how knows the required C program. help me!
best
Old   May 19, 2005, 09:02
Default Re: periodic source term!!
M.Sundar
Please refer UDF manual [Solved examples]
Old   May 20, 2005, 01:07
andre
I see the udf manual. but it hasn't a term for time. I don't know how i can use time in source term.
Old   May 30, 2005, 14:27
ramesh
Hi U can catch flow time as well as time step in Fluent. Check the UDF manual. If ur t in the equation is flow time then it is possible to include.
momentum source term zwdi FLUENT 14 June 27, 2017 15:40
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
