June 13, 2005, 11:56 |
Energy in porous media
From the user guide, it seems that the gov. eqn. for energy is the averaged one of fluid and solid together( eqn 6.19-8 for version 6.1). What if I have different temp for the fluid and the porous material ? To be more clearly, I want to model the heat transfer btwn the fluid and the solid, how can I 'tell' FLUENT to calculate the energy for two phases separately ? Any suggestion will be highly appreciated! Yong |
June 13, 2005, 15:58 |
Re: Energy in porous media
You would need to do some sort of UDF, I suppose. This might be complicated, as a porous medium is just a fluid region with an additional momentum sink term. The solid doesn't exist in the numeric model.
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 7 | May 14, 2020 16:34 |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
energy equation in porous media? | Tony | FLUENT | 1 | June 9, 2015 13:41 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 10:34 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
