Debugging 3d parabolic udf
Old   June 10, 2005, 00:00
Default Debugging 3d parabolic udf
david
Hi all,
I am just starting my first 3d case and I am having problems with this UDF posted in another thread. I use it for a 3d laminar pipe flow. I was wondering if someone had encountered difficulty using this UDF. The imposed velocity profile should be imposed on the face perpendicular to the z-axis right?
When interpreting I get the following error message. Find below the UDF in question.
Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: #f
Best Regards, David
DEFINE_PROFILE(z_velocity, thread, position)
float r, x[2];
face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
/* 3D: r = sqrt(pow(x[0]-xc, 2)+pow(x[1]-yc, 2)); */
/* here: r means not radius but distance from the centerline or symmetryline */ r = x[0]-xc;
F_PROFILE(f,thread,position)=2*umean*(1-pow(r/radius,2));
/* controle output
printf("x=%.6f\t r=%.6f\t
u=%.5f\n",x[0],r,2*umean*(1-pow(r/radius,2))); */
end_f_loop(f, thread)
Old   June 10, 2005, 06:37
Default Re: Debugging 3d parabolic udf
dirk
Hello David,
I just tried this UDF. You forgot to declare some variables. After doing this it works well.
Dirk
Old   June 10, 2005, 15:51
david
Hi Dirk,
Thanks for your response. You were right, I had forgotten to declare some variables. But I now have another problem. Consider the UDF posted which was adapted from the original. I include printf commands to see if UDF executes properly. It appears that the UDF interprets correctly but it seems that FLUENT avoids the code starting from
"begin_f_loop(f, thread)" downward. Do you have any clues why this is happening?
Best Regards David
--------------------------------------------------- #include "udf.h"
/* coordinates of the inlet center */
#define xc 0.
#define yc 0.
/* here: radius means half slit with or distance from the symmetryline to the wall */
#define radius 0.0014
/*mean velocity: (Ufree=Ucenter!!) */
#define umean 0.232
float r, x[2];
face_t f;
r = sqrt(pow(x[0]-xc, 2)+pow(x[1]-yc, 2)); printf("r=%.6f\n",r);
printf("x=%.6f\t r=%.6f\t u=%.5f\n",x[0],r,2*umean*(1-pow(r/radius,2)));
Old   June 11, 2005, 05:07
dirk
This works fine. Just apply the inlet BC, make one iteration and plot the inlet velocity.
Old   June 13, 2005, 14:20
david
Hi Dirk, Thank you for responding. I have tried this and it still does not work. I mean it interprets fine but when I apply this profile to my velocity inlet and iterate nothing happens.
I am suspecting that something might be wrong with my mesh itself. Do you have a small 3d mesh file that I could use to test further my UDF as Fluent manual does not provide such mesh files.
If this not possible perhaps I could email my mesh file so you can have a look at it...
Best Regards, David
UDF Unsteady velocity parabolic profile Rashad FLUENT 3 October 1, 2018 15:27
UDF error - parabolic velocity profile - 3D turbine Zaqie Fluent UDF and Scheme Programming 9 June 25, 2016 19:08
help debugging Beam deflection UDF josik_1982 Fluent UDF and Scheme Programming 0 December 19, 2010 17:36
How to define a parabolic velocity inlet of particles with UDF zumaqiong FLUENT 2 February 22, 2010 09:46
IdeasUnvToFoam Bug amp Fix benru OpenFOAM Bugs 42 November 13, 2009 07:59
