a math operator in UDF
Old   May 24, 2005, 12:22
Default a math operator in UDF
lichun Dong
hi, All:
How to get the reminder of two number in UDF, like 7.2 % 2 = 1.2 in C. I need to input a asymmetric moving wall condition which has a period of 2*pi. I tried % in UDF, it does not work. Anybody has an experience?
Thanks a lot
Old   May 24, 2005, 13:12
Default Re: a math operator in UDF
Mark
I believe you use the div command to store the quotient and remainder. Then access the remainder using .rem
Example:
divide = div(numerator,denominator); remainder = divide.rem;
Mark
Old   May 24, 2005, 13:13
Mark
Sorry, the example came out poorly formatted.
Example:
Mark
Old   May 24, 2005, 15:34
lichun Dong
hi, Mark:
Thanks a lot, so what is the data type of divide? Array of real?
Lichun
Old   May 24, 2005, 15:56
Mark
Sorry, I should have included that with the example. I declared the variable using:
div_t divide;
So that would make it a type "div_t" (I think).
Mark
Old   May 29, 2005, 07:53
Saad
I think you can use the function rem(a,b). For example, rem(5,3) = 2.
Saad
Old   June 7, 2005, 10:11
Mahesh
I have used once to define square wave velocity function as below. ================================= #include "udf.h" DEFINE_PROFILE(sq50_velocity, thread, nv) { face_t f; real t= RP_Get_Real("flow-time"); int p,q; real T=0.01; p=t/(T/2); q=p%2;
begin_f_loop(f, thread) { if(q==0)
F_PROFILE(f, thread, nv) =30;
else
F_PROFILE(f, thread, nv) = 0; } end_f_loop(f, thread) }
Old   June 18, 2005, 22:04
manish mehta
Dear Mahesh,
I am really new with UDF files. If my square wave needs to go from 180 psi to 0 psi, and it has a frequency of 10 Hz. How would I go about doing this?
I thought of doing a Fourier Transform of a square wave that I need, but there are problems with that approach. Any advice would be benefical.
Hope you can help. -Manish
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 11:29
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
