HELP how to simulate my problem?
Old   July 12, 2005, 12:50
Default HELP how to simulate my problem?
Romain
Hello, Could you please tell me how to simulate this following problem: I have a tube(100mm) full of oil at 8bars, on the left side the tube is closed by a wall which is hooked to a spring(so the wall can move), on the right side there is a winnow, and behind this winnow there is oil at 20bars. I want to open the winnow and see the movement of the wall with the spring until pression is stabilize to 20bars.The problem is that there is not really a flow of oil, the oil at 20bars "push" the oil at 8bars until the pression is stabilized. Please, what is the good configuration of simulation for this problem? because I find values completly false. Thanks,regards
Need any WHATEVER Help,please. Heat-Flow problem Amr FLUENT 1 March 15, 2013 11:47
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
