July 21, 2005, 22:26 |
Error while reading mesh file
Hi Fluent Users
iam getting an error while reading the mesh file, its a 3d geometry and the error its says is " skipping zone inlet_outlet_shadow (not referenced by grid)". here the inlet and outlet is periodic. any suggestion is appreciated. thanks in advanced regards sak |
July 22, 2005, 03:48 |
Re: Error while reading mesh file
UDF could help I think.
Sham. |
July 22, 2005, 20:45 |
even i'm getting the same error, is it really a error, or we can skip this. i'm solving periodic rotational flow
July 25, 2005, 08:28 |
inlet_outlet is your periodic zone... inlet_outlet_shadow is a "shadow zone", which is basically a copy of inlet_outlet used to compute values across a periodic zone. It's not a problem. If Fluent requires another shadow zone, then it will create it.
Jason |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' | mfiandor | OpenFOAM Installation | 2 | January 25, 2010 09:50 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
wrong dimensions when reading mesh file | stella | FLUENT | 3 | October 12, 2005 12:30 |
